[GRASS-dev] Re: PIxel-wise regression contribution
Damien O'Grady damien.ogrady at my.jcu.edu.au
Sun May 20 20:17:59 EDT 2012
I am not sure from the documentation how to do this.  I have an
osgeo-userid, but no write access to the addons list (I assume).  I
would be grateful if you would point me in the right direction.
Regards
Damien
 On Sat, 2012-05-19 at 02:51 -0700, Helmut Kudrnovsky wrote:
> >I would like to contribute a script that I have used in my research to
> >the broader field.  The script carries out linear regression, except
> >that rather than using two rasters for the x and y variables, it uses
> >any number of pairs of rasters, allowing the regression to be carried
> >out across a time series, resulting in a slope, intercept and R^2 values
> >for each pixel.
> >The crunch is that it is written in perl, as this is what I know best
> >and it serves me well.  I have done my best to conform to the stated
> >standards, and I have produced a fairly detailed manual page.  This will
> >give you a better idea of what the script does, with examples.  I attach
> >the script and html here.  I hope that you will consider making it
> >available to others.
> could you add your script to grass-addons? so it wouldn't be maybe lost in
> the mailing list.
> grass-addons:
>    http://grass.osgeo.org/wiki/GRASS_AddOns
> you need a osgeo-userid to add things to grass addons:
>    http://www.osgeo.org/osgeo_userid
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.n6.nabble.com/PIxel-wise-regression-contribution-tp4975696p4975706.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
