[GRASS-dev] broken stuff in vector modules
Anna Kratochvílová
kratochanna at gmail.com
Fri May 25 03:29:27 EDT 2012
On Wed, May 23, 2012 at 4:43 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> 2) To get around this, I thought I'd try to get the length of the line that
> connects each site point with its nearest waterway (a v.distance option).
> But when I tried to make a new table for this in the table manager, I find
> that I cannot access the "table description" section of the "manage layers"
> page in the attribute table manager. This is again because wx.StaticBox
> needs to be defined in a particular order or the Mac interface cannot access
> it. This has been a recurrent problem with wx.StaticBox. The StaticBox must
> be instantiated before any of its contents.
This should be fixed now. If you find this bug elsewhere, tell me or
you can fix it easily yourself.
Anna
