[GRASS-dev] Re: [GRASS GIS] #1584: error in r.walk help page
trac at osgeo.org
Fri May 25 23:29:31 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Docs | Version: unspecified
Keywords: r.walk | Platform: All
Cpu: All |
Comment(by dkavanagh):
Hamish - I believe the help is correct. c and d are multiplied by the
delta, which in a downward slope will be negative. Here is an example from
the code - fcost_dtm = (double)((double)(W_dtm - my_dtm) * c);
Replying to [ticket:1584 hamish]:
> one from Agustin:
> the documentation in r.walk is wrong. It says:
> "The default values for a, b, c, d are those proposed by Langmuir
> (0.72, 6.0, 1.9998, -1.9998)"
> and it should say:
> (0.72, 6.0, -1.9998, 1.9998)"
> because the point is that you go faster on gentle slopes and more
> slowly on steeper slopes and those values are in m/s
> The worrying question is whether these values are also wrong in the
> default values of r.walk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:3>
