[GRASS-dev] [GRASS GIS] #1570: In GRASS6.4.2RC3 with wxpython GUI the option Add raster cell numbers doesn't work
GRASS GIS trac at osgeo.org
Sun May 27 08:17:21 PDT 2012
doesn't work
 Reporter:  clerici  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.2
Component:  wxGUI    |     Version:  6.4.2 RCs
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by annakrat):
 Should be fixed in r51824, r51825, r51827 (all branches). The problem is
 that you must check "Constrain display resolution to computational
 settings" in "Display resolution" in Map Display statusbar (now it asks
 you and then it's done automaticaly) and be careful how many cells you are
 displaying.
 Anna
Ticket URL: <https://trac.osgeo.org/grass/ticket/1570#comment:1>
