[GRASS-dev] [GRASS GIS] #1666: v.proj - Error in pj_do_transform
GRASS GIS trac at osgeo.org
Mon May 28 03:31:32 PDT 2012
 Reporter:  spiderplant0  |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  6.4.3
Component:  Vector        |     Version:  6.4.2
 Keywords:                |    Platform:  MSWindows 7
      Cpu:  x86-64        |
 Consider this data organization...
 e:\work\grass\GB\mapset1
 e:\work\grass\UK_EPSG900913\mapset1
 I.e. 'mapset1' folders contain the 'vector' and 'dbf' directories etc.
 And I have two locations 'GB' and 'UK_EPSG900913' The projections are set
 to OSGB36 and epsg900913 respectively.
 I have a map in the 'GB' location that I wish to re-project to epsg900913.
 So I choose the location as 'UK_EPSG900913' and 'mapset1' and then I run
 this command...
 v.proj input=scot location=GB mapset=mapset1 output=scot1
 It works on Linux but when I run this on windows I get the error...
 Reprojecting primitives:
 pj_transform() failed: failed to load datum shift file
 ERROR: Error in pj_do_transform
 Tested on..[[BR]]
 Windows 7 64-bit with GRASS 6.4.2 32-bit - get error[[BR]]
 Ubuntu 12.04 64-bit with GRASS 6.4.2 64-bit - OK[[BR]]
 Ubuntu 11.10 32-bit with GRASS 6.4.1 32-bit - OK[[BR]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/1666>
