[GRASS-dev] [GRASS GIS] #1779: v.net.centrality: output map has features' cat values in layer 2, but table connected to layer 1
GRASS GIS trac at osgeo.org
Thu Nov 1 10:02:09 PDT 2012
 Reporter:  mlennert                |       Owner:  grass-dev@…
     Type:  defect                  |      Status:  new
 Priority:  normal                  |   Milestone:  7.0.0
Component:  Vector                  |     Version:  svn-trunk
 Keywords:  v.net.centrality layer  |    Platform:  Unspecified
      Cpu:  Unspecified             |
 v.net.centrality creates an output map with points representing those
 nodes for which centralities were calculated. As customary in network
 modules (at lest in trunk), these points have their cat values in layer 2.
 The attribute table is linked to layer 1, however.
 As the output is only points, IMHO the cat values should be in layer 1.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1779>
