[GRASS-dev] r.modis in GRASS 7 trunk
Martin Landa
landa.martin at gmail.com
Fri Nov 2 02:17:21 PDT 2012
2012/10/31 Glynn Clements <glynn at gclements.plus.com>:
> Relegating something to add-ons is a reliable way to reduce the amount
> of developer oversight it gets. E.g. currently you can't just "make"
> the add-ons/grass7 directory (it lacks a Makefile), so most developers
> won't even try to compile it. If the modules were in trunk, developers
> may notice errors or warnings as part of the normal build process.
btw, there are logs from WinGRASS AddOns packaging available online [1].
Martin
[1] http://wingrass.fsv.cvut.cz/grass70/addons/logs/
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
