[GRASS-dev] [GRASS GIS] #1780: v.net.centrality: betweenness centrality seems wrong
trac at osgeo.org
Fri Nov 2 06:30:24 PDT 2012
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: invalid | Keywords: v.net.centrality betweenness
Platform: Unspecified | Cpu: Unspecified
Comment(by mmetz):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 mmetz]:
> > Replying to [ticket:1780 mlennert]:
v.net streets_wake points=schools_wake thresh=200 out=network op=connect
v.net.centrality input=network alayer=1 nlayer=2 output=centrality
cats=1-108 degree=degree closeness=closeness betweenness=betw
eigenvector=eig
> Ok, I see my error: since the schools are connected by short lines to
the network, no shortest path between two other schools ever passes
through those short lines and thus betweenness is 0. The only exception
are those schools which are right next to another school and where the
latter is connected to the network via the former. Then all shortest paths
from the latter go through the former...
> This raises the question of whether it would be envisageable / desirable
to add an option to v.net allowing to create nodes _on_ the existing
network when connecting new points, instead of connecting these points by
short lines. IOW, instead of currently adding a short line from any point
in the given threshold to the network, "just" create a new node on a point
of the network that is closest to the point you wish to add. Am I being
clear ? ;-)
Perfectly. Please try the new -s flag in r53665 for v.net to "Snap points
to network". I think this makes sense for network preparation in general,
particularly for features like schools, hospitals etc. that are
represented by a point.
With the above test command, -s flag added, there are now only two points
with a betweenness of 0.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1780#comment:3>
