[GRASS-dev] installing r.modis fails
Paulo van Breugel p.vanbreugel at gmail.com
Fri Nov 2 15:24:11 PDT 2012
Hi Helmut,
The r.modis help files states that "It requires the MODIS Reprojection
Tool<https://lpdaac.usgs.gov/lpdaac/tools/modis_reprojection_tool>to
be installed while
pyModis <http://gis.cri.fmach.it/development/pyModis> is included in the *
r.modis* suite". Also because there is a folder libmodis in the r.modis
source folder I assumed that installing r.modis would take care
automatically of pyModis, but that was a wrong assumption?
I have installed the Modis Reprojection Tool, but I see one has to define
the path when running r.modis.download, so I guess this is not influencing
the install of r.modis?
Cheers
Paulo
On Fri, Nov 2, 2012 at 11:13 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi Paulo,
> >ERROR: No module named rmodislib
> >make[1]: *** [r.modis.download.tmp.html] Error 1
> >make[1]: *** [r.modis.import.tmp.html] Error 1
> >Installing...
> the addons-wiki [1]  says:
> [...]  It uses the pyModis library and the MODIS Reprojection Tool software
> to convert, mosaik and process MODIS data.
> do you have these dependencies installed?
> best regards
> Helmut
> [1] http://grass.osgeo.org/wiki/GRASS_AddOns#r.modis
> best regards
> Helmut
> http://osgeo-org.1560.n6.nabble.com/installing-r-modis-fails-tp5012466p5013643.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121102/a4cced49/attachment.html>
