[GRASS-dev] r.modis in GRASS 7 trunk
Markus Neteler neteler at osgeo.org
Sun Nov 4 04:59:30 PST 2012
On Sat, Nov 3, 2012 at 6:29 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> general/g.cloud:
>         ImportError: No module named pexpect
> g.cloud.py imports pexpect (which isn't part of the standard library)
> but doesn't use it. cloud_ssh.py does use pexpect for scripting "ssh".
> It appears to be doing this primarily so that it can feed it a
> password, which is a bad idea (use ssh-agent if you want to be able to
> use ssh without having to provide a password).
> Also: includes a couple of shell scripts. cloud_collect.sh deals with
> GRASS and could probably be converted to Python. cloud_mail.sh relies
> upon a command-line "mail" program which is not particularly portable.
Luca Delucchi and me will work on this.
> raster/r.agent:
>         make: *** No targets specified and no makefile found.  Stop.
This is slow work in progress (the author and me). The Makefile will be
added once the module starts to become usable.
> raster/r.convert:
> Also: consists entirely of shell scripts.
Hamish's script for a new raster directory layout in GRASS. Likely
not happening in GRASS7, so better don't add a Makefile to avoid
a mess for "innocent" users.
> vector/v.in.redwg:
>         dwg.h: No such file or directory
Needs http://www.gnu.org/software/libredwg/ on the server.
Markus
