[GRASS-dev] wxGUI lock import problem
Martin Landa landa.martin at gmail.com
Sun Nov 4 13:27:44 PST 2012
recently I started to have problem with wxGUI in G7. When starting GRASS
  File "/home/martin/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/gis_set.py",
line 36, in <module>
    from core import globalvar
RuntimeError: not holding the import lock
  File "/home/martin/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/wxgui.py",
line 27, in <module>
After quiting the GUI I need to press Ctrl-C and then I get bunch of
  File "/home/martin/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/core.py",
line 56, in __init__
    ps = pipe_command(*args, **kwargs)
line 211, in pipe_command
startupinfo, creationflags)
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    return start_command(*args, **kwargs)
line 169, in start_command
    if debug_level() > 0:
line 1346, in debug_level
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1244, in _execute_child
    _debug_level = int(gisenv().get('DEBUG', 0))
line 682, in gisenv
    data = _eintr_retry_call(os.read, errpipe_read, 1048576)
  File "/usr/lib/python2.7/subprocess.py", line 478, in _eintr_retry_call
    s = read_command("g.gisenv", flags='n')
line 234, in read_command
    return func(*args)
KeyboardInterrupt  File
line 173, in start_command
    return Popen(args, **popts)
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1247, in _execute_child
    os.close(errpipe_read)
OSError: [Errno 9] Bad file descriptor
I am not sure what could be the reason. Very wild guess, couldn't be
related to r53674.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
