[GRASS-dev] making GEOS as manatory dependency for grass7 ?
Benjamin Ducke
benducke at fastmail.fm
Sun Nov 4 14:32:41 PST 2012
I maintain a separate set of GRASS Windows
binaries, for use from within gvSIG/SEXTANTE.
Those are compiled from scratch, using only MinGW.
I like to avoid proprietary tools.
It's pretty straight-forward these days to
get the mandatory dependencies and most
GDAL drivers compiled using MinGW and MSYS.
Indeed: MinGW and VC DLLs do not mix well, so
it's better to compile everything with either
one or the other.
Ben
On 11/04/2012 11:25 PM, Martin Landa wrote:
> Hi,
> 2012/11/4 Benjamin Ducke <benducke at fastmail.fm>:
>> This might be a but "puritanical" of me, but
>> I really think that all of GRASS' mandatory
>> dependencies on Windows should compile easily
>> using MinGW, and not require proprietary
>> tools.
> sorry, probably I am not getting the point. Then you would need to
> recompile major part of OSGeo4W packages (due to VC).
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
