[GRASS-dev] r.modis.download
Paulo van Breugel p.vanbreugel at gmail.com
Tue Nov 6 01:22:31 PST 2012
Hi Luca
My system info:
GRASS version: 7.0.svn
GRASS SVN Revision:
53689
GIS Library Revision: 52468
(2012-07-27)
GDAL/OGR:
1.9.2
PROJ.4:
4.7.0
GEOS:
3.3.3
Python:
2.7.3
wxPython:
2.8.12.1
Platform: Linux-3.5.0-17-generic-x86_64-with-Ubuntu-12.10-quantal
When running r.modis.import, I am getting the following error output (just
copying the first few lines and the last part as the whole error message is
too long):
  File "/home/paulo/.grass7/addons/
scripts/r.modis.import",
line 510, in <module>
    sys.exit(main())
  File "/home/paulo/.grass7/addons/scripts/r.modis.import",
line 478, in main
    version = grass.core.version()
  File "/usr/local/grass7/grass-7.0.svn/etc/python/grass/scr
ipt/core.py", line 1332, in version
    flags = 'rge')
ipt/core.py", line 274, in parse_command
    res = read_command(*args, **kwargs)
ipt/core.py", line 56, in __init__
    startupinfo, creationflags)
  File "/usr/lib/python2.7/subprocess.py", line 679, in
__init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1129, in
_execute_child
    if isinstance(args, types.StringTypes):
RuntimeError: maximum recursion depth exceeded while calling
a Python object
If you want the whole error message, please let me know.
Paulo
On Tue, Nov 6, 2012 at 9:47 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2012/11/6 Paulo van Breugel <p.vanbreugel at gmail.com>:
> > Just want to confirm I am getting the same errors. I have normal access
> to
> > the ftp site, so I guess that should not be a cause of this problem?
> You are running r.modis in which OS?
> could you send all the error log?
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121106/3be803ab/attachment.html>
