[GRASS-dev] r.modis.download
Martin Landa landa.martin at gmail.com
Tue Nov 6 02:06:03 PST 2012
2012/11/6 Luca Delucchi <lucadeluge at gmail.com>:
>>     if debug_level() > 0:
>>   File "/usr/local/grass7/grass-7.0.svn/etc/python/grass/scr
>> ipt/core.py", line 1346, in debug_level
>>     _debug_level = int(gisenv().get('DEBUG', 0))
>> ipt/core.py", line 682, in gisenv
>>     s = read_command("g.gisenv", flags='n')
> the error is in grass.core.version(). I try also to run it from
> console and I obtain the same error.
> I'm looking the code but it's a little bit confused because a lot of
> module are called and I really don't understand where is the bug.
see
http://lists.osgeo.org/pipermail/grass-dev/2012-November/060670.html
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
