[GRASS-dev] [GRASS GIS] #1786: r.resamp.rst fails with message "split_and_interpolate() failed
trac at osgeo.org
Tue Nov 6 19:13:40 PST 2012
Reporter: bko | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.1
Keywords: | Platform: Linux
Cpu: x86-64 |
The following command fails on my computer:[[BR]]
r.resamp.rst input=nearest_hydro_permanent_all_200 at PERMANENT ew_res=10
ns_res=10 elev=nearest_hydro_permanent_all_200_10m overlap=3 zmult=1.0
tension=40.
Here is the output from the command:[[BR]]
'''65910784 bytes of disk space for temp files.'''
Temporarily changing the region to desired resolution ...
Changing back to the original region ...
Percent complete:
Cannot fseek elev offset2=-2147383136
Cannot fseek elev offset2=-2147382860
Cannot fseek elev offset2=-2147382584
Cannot fseek elev offset2=-2147382308
Cannot fseek elev offset2=-2147382032
Cannot fseek elev offset2=-2147381756
Cannot fseek elev offset2=-2147381480
Cannot fseek elev offset2=-2147381204
Cannot fseek elev offset2=-2147380928
Cannot fseek elev offset2=-2147380652
Cannot fseek elev offset2=-2147380376
Cannot fseek elev offset2=-2147380100
Cannot fseek elev offset2=-2147379824
Cannot fseek elev offset2=-2147379548
Cannot fseek elev offset2=-2147379272
Cannot fseek elev offset2=-2147378996
Cannot fseek elev offset2=-2147378720
Cannot fseek elev offset2=-2147378444
Cannot fseek elev offset2=-2147378168
Cannot fseek elev offset2=-2147377892
Cannot fseek elev offset2=-2147377616
Cannot fseek elev offset2=-2147377340
Cannot fseek elev offset2=-2147377064
Cannot fseek elev offset2=-2147376788
Cannot fseek elev offset2=-2147376512
Cannot fseek elev offset2=-2147376236
Cannot fseek elev offset2=-2147375960
Cannot fseek elev offset2=-2147375684
Cannot fseek elev offset2=-2147375408
Cannot fseek elev offset2=-2147375132
Cannot fseek elev offset2=-2147374856
Cannot fseek elev offset2=-2147374576
dnorm in mainc after grid before out1= 1249.036216
The command fails in exactly the same way on two different systems:
1. Ubuntu 10.04 with grass 6.4 RC with amd64 processor and 64 bit OS
2. Ubuntu 10.04 with grass 6.4.1 with amd64 processor and 64 bit OS
This exact command does work on a project that is about 1/10th the size of
the one on which the command failed.
I looked at the code and wonder if I had an integer overflow (possibly on
the variable sdisk). My region is huge and my resolution is high.
Region:[[BR]]
projection: 1 (UTM)
zone: 12
datum: nad83
ellipsoid: grs80
north: 6399780
south: 6058660
west: 243410
east: 563010
nsres: 10
ewres: 10
rows: 34112
cols: 31960
cells: 1090219520
I find it strange that the '''65910784 bytes of disk space for temp
files.''' didn't format to 65.91 MB ....
Makes me think overflow but I my C knowledge is just about nonexistent.
Cheers!
Ticket URL: <http://trac.osgeo.org/grass/ticket/1786>
