[GRASS-dev] [GRASS GIS] #1786: r.resamp.rst fails with message "split_and_interpolate() failed
GRASS GIS trac at osgeo.org
Wed Nov 7 00:50:04 PST 2012
 Reporter:  bko     |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.3
Component:  Raster  |     Version:  6.4.1
 Keywords:          |    Platform:  Linux
      Cpu:  x86-64  |
Comment(by neteler):
 Replying to [ticket:1786 bko]:
 > The following command fails on my computer:[[BR]]
 > r.resamp.rst
 > Cannot fseek elev offset2=-2147383136
 It will be an overflow of 2^31, i.e. the 2GB limit.
 > The command fails in exactly the same way on two different systems:
 > 1. Ubuntu 10.04 with grass 6.4 RC with amd64 processor and 64 bit OS
 > 2. Ubuntu 10.04 with grass 6.4.1 with amd64 processor and 64 bit OS
 Have these versions been compiled with --enable-largefile?
 If yes, can you try GRASS 7 instead which has improved Large File support?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1786#comment:2>
