[GRASS-dev] [GRASS GIS] #1789: v.hull: should not use
GRASS GIS trac at osgeo.org
Fri Nov 9 02:32:07 PST 2012
 Reporter:  neteler  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.3
Component:  Vector   |     Version:  svn-releasebranch64
 Keywords:  v.hull   |    Platform:  All
      Cpu:  All      |
 If the current region is not set to the vector map, v.hull
 fails with:
 v.hull training_turkey_087VI174 out=training_turkey_087VI174_hull
 ERROR: Convex hull calculation requires at least three points. Exiting.
 The reason is in main.c, line 311:
     /* load site coordinates */
     G_get_window(&window);
     numSitePoints = loadSiteCoordinates(&Map, &points, all->answer,
 &window);
 In loadSiteCoordinates()
     /* copy window to box */
     Vect_region_box(window, &box);
 I wonder why it is made region sensitive (untypical for GRASS
 vector commands)...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1789>
