[GRASS-dev] [GRASS GIS] #1796: wingrass7: some db.*-modules fails
GRASS GIS trac at osgeo.org
Mon Nov 12 08:32:36 PST 2012
 Reporter:  hellik    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  7.0.0
Component:  Database  |     Version:  svn-trunk
 Keywords:            |    Platform:  MSWindows 7
      Cpu:  x86-64    |
 fails:
 db.databases --verbose
 D2/3: dbDbmscap(): opendir
 [C:\OSGeo4W\apps\grass\grass-7.0.svn\driver\db\]
 D3/3: win_spawn: args = C:\windows\system32\cmd.exe /c
 "C:\OSGeo4W\apps\grass\grass-7.0.svn\driver\db\dbf.exe"
 D1/3: db_d_init_error(): DBF
 dbmi: db_list_databases() not implemented
 ERROR: Kann Datenbanken nicht auflisten.
 ERROR: Databases can't be listet.
 (Mon Nov 12 17:20:18 2012) Command finished (0 sec)
 ok:
 db.tables --verbose
 ccm2_example_wgs84
 ccm2_example_wgs843d_ccm2_example_wgs84
 ccm2_example_wgs84_smaller19
 riverclipped
 testarea
 testareaisel
 (Mon Nov 12 17:23:17 2012) Command finished (0 sec)
 fails:
 db.describe --verbose table=ccm2_example_wgs84
 D2/3: DBF: db__driver_open_database() name =
 '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
 D3/3: tokens[0] = $GISDBASE
 D3/3:    -> C:\grassdata
 D3/3: tokens[1] = $LOCATION_NAME
 D3/3:    -> srtm41gar
 D3/3: tokens[2] = $MAPSET
 D3/3:    -> vectexample
 D3/3: tokens[3] = dbf
 D2/3: db.name = C:\grassdata/srtm41gar/vectexample/dbf/
 D2/3: add_table(): table = ccm2_example_wgs84 name =
 ccm2_example_wgs84.dbf
 ccm2_example_wgs843d_ccm2_example_wgs84 name =
 ccm2_example_wgs843d_ccm2_example_wgs84.dbf
 D2/3: add_table(): table = ccm2_example_wgs84_smaller19 name
 = ccm2_example_wgs84_smaller19.dbf
 D2/3: add_table(): table = riverclipped name =
 riverclipped.dbf
 D2/3: add_table(): table = testarea name = testarea.dbf
 D2/3: add_table(): table = testareaisel name =
 testareaisel.dbf
 D2/3: find_table(): table = ccm2_example_wgs84
 D2/3:   ? ccm2_example_wgs84
 D2/3: load_table_head(): tab = 0, C:\grassdata/srtm41gar/vec
 texample/dbf/\ccm2_example_wgs84.dbf
 D2/3:   ncols = 25
 D2/3:   DBFFieldType 1
 D3/3: add_column(): tab = 0, type = 2, name = cat, width =
 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = WSO1_ID, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = WSO_ID, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = RVR_ID, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = FROMNODE,
 width = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = TONODE, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = STRAHLER,
 D2/3:   DBFFieldType 2
 D3/3: add_column(): tab = 0, type = 3, name = PFAFSTETTE,
 width = 20, decimals = 6
 D3/3: add_column(): tab = 0, type = 2, name = NEXTDOWNID,
 D2/3:   DBFFieldType 0
 D3/3: add_column(): tab = 0, type = 1, name = LONGPATH,
 width = 1, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = MAINDRAIN_,
 D3/3: add_column(): tab = 0, type = 2, name = MAINDRAIN1,
 D3/3: add_column(): tab = 0, type = 2, name = LENGTH, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = CUM_LEN, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = PIXELS_100,
 D3/3: add_column(): tab = 0, type = 3, name = CATCHMENT_,
 D3/3: add_column(): tab = 0, type = 2, name = CONT_PIXEL,
 D3/3: add_column(): tab = 0, type = 2, name = DRAIN_KM2,
 D3/3: add_column(): tab = 0, type = 3, name = ALT_GRADIE,
 D3/3: add_column(): tab = 0, type = 2, name = BURNED, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = CONFIDENCE,
 D3/3: add_column(): tab = 0, type = 2, name = WINDOW, width
 = 11, decimals = 0
 D3/3: add_column(): tab = 0, type = 2, name = OBJECTID,
 D3/3: add_column(): tab = 0, type = 3, name = SHAPE_Leng,
 D3/3: add_column(): tab = 0, type = 1, name = grenze, width
 = 1, decimals = 0
 fails:
 db.columns --verbose table=ccm2_example_wgs84
 D3/3:    -> srtm41gar
 riverclipped.dbf
 testareaisel.dbf
 D2/3:   ncols = 25
 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 11, decimals = 0
 = 1, decimals = 0
 Helmut
 System Info
 GRASS version: 7.0.svn
 GRASS SVN Revision: 53771
 GIS Library Revision: 52468 (2012-07-27)
 GDAL/OGR: 1.9.2
 PROJ.4: 4.8.0
 GEOS: 3.3.5
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1796>
