[GRASS-dev] [GRASS GIS] #1795: segmentation fault in v.distance db_describe_table
GRASS GIS trac at osgeo.org
Wed Nov 14 05:04:33 PST 2012
 Reporter:  pertusus    |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.distance  |    Platform:  Linux
      Cpu:  x86-64      |
Comment(by pertusus):
 Indeed, there is no more segfault anymore, but v.distance do not upload to
 the table.
 > v.db.select test_point
 cat|dbl_1|dbl_2|int_1|cat_basin
 1|1535075.28996661|-2045868.67996559|1|
 cat_basin should be the cat of the test_bas point since the point is in
 test_bas.
 > v.db.select test_bas
 cat
 354
 Should I open another bug?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1795#comment:3>
