[GRASS-dev] [GRASS GIS] #1800: v.kernel crashes after long execution
GRASS GIS trac at osgeo.org
Mon Nov 19 00:10:30 PST 2012
 Reporter:  arencambre  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  6.4.2
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by mmetz):
 Replying to [comment:3 arencambre]:
 > I have over 100 GB disk space. I didn't detect much disk utilization
 during the run.
 Over 100 GB of free disk space?
 > Not clear what {{{r.mapcalc "mockingbird_and_central_high_resolution =
 rand(0.0, 1.0)"}}} is going to do?
 '''mockingbird_and_central_high_resolution''' is the bad output from the
 v.kernel run that crashed.
 This should tell you if the problem is specific to v.kernel or more
 general, because the crash was caused by the GRASS library handling raster
 IO, not by v.kernel itself. Therefore the idea is to create a raster map
 with the same type and name for the same region settings, but with a
 different module in order to find out if the crash in the GRASS library is
 specific to v.kernel or more general.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1800#comment:4>
