[GRASS-dev] [GRASS GIS] #1798: all relevant vector modules should have cats and where parameters
trac at osgeo.org
Mon Nov 19 00:15:04 PST 2012
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: where cats parameter | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:5 hellik]:
> Replying to [comment:4 mmetz]:
> > IIUC, these virtual maps should behave just like normal maps: from a
user perspective, it could look like
v.extract -v (-v as new flag to create a view or virtual vector)
v.buffer
> > instead of
v.extract
v.buffer
[Sorry, I meant v.extract]
> AFAIU a virtual map could be a "permanent" selection by cats/where,
store this virtual map in the mapset and use this virtual map as input for
processing by the v.*-modules.
v.make.virtual input=vector output=virtualmap cat=1-10 where A < 10
v.* input=virtualmap
The advantage of a virtual map over using v.extract to get a "permanent"
selection by cats/where is not clear to me because the result of v.extract
can be processed faster than a virtual map.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1798#comment:6>
