[GRASS-dev] [GRASS GIS] #1798: all relevant vector modules should have cats and where parameters
GRASS GIS trac at osgeo.org
Mon Nov 19 10:36:31 PST 2012
 Reporter:  mlennert              |       Owner:  grass-dev@…
     Type:  enhancement           |      Status:  new
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  where cats parameter  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by hellik):
 Replying to [comment:7 mlennert]:
 > The only real advantage I can see is if whenever you modify the original
 map, your virtual map gets modified also (just like a database view). You
 then don't have to run v.extract each time.
 IMHO that would ease heavy vector analysis a lot. I'm often using this
 approach in some other GIS software ;o)
 >Also, you might consider it useful to avoid clutter if you can list views
 separately from vector maps (i.e. g.list view).
 good idea
 > a virtual map then would only save you the typing of these parameters.
 at least me being lazy and wingrass-GUI-oriented would be happy
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1798#comment:9>
