[GRASS-dev] Moving r53760 to some lib
Markus Metz markus.metz.giswork at gmail.com
Wed Nov 21 07:18:37 PST 2012
On Wed, Nov 21, 2012 at 3:59 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/11/21 Maris Nartiss <maris.gis at gmail.com>:
>> Your code in r53760 seems good. I would suggest to move it to some
>> library, still no idea where it should go. Probably Vlib? As it would
>> reduce code duplication and use of home-brew suboptimal code.
> Vlib seems to be a good place, see also similar (more options
> included) stuff in v.edit [1].
I agree, particularly if more modules will get cats/where options,
maybe also to work with virtual vector maps. I would suggest two new
functions, one to parse cats/where/field options, essentially the
parse_filter_options() fn, another one to check categories against
these filters.
Markus M
