[GRASS-dev] [GRASS GIS] #1808: g.remove WXGUI interface causes buffer overflow in g.findfile
GRASS GIS trac at osgeo.org
Fri Nov 23 01:17:44 PST 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 Steps to reproduce:
  * launch g.remove and select a lot of raster maps from list. In my case
 it resulted in 280 symbol long comma separated list for rast= parameter.
  * RUN :)
  * Copy command and run from CLI just fine without any problems.
 *** buffer overflow detected ***: g.findfile terminated
 ======= Backtrace: =========
 /lib64/libc.so.6(__fortify_fail+0x37)[0x7f9ace1c38d7]
 /lib64/libc.so.6(+0xfe6f0)[0x7f9ace1c16f0]
 g.findfile(main+0x1c9)[0x4011c9]
 /lib64/libc.so.6(__libc_start_main+0xed)[0x7f9ace0e791d]
 g.findfile[0x401479]
 ======= Memory map: ========
 00400000-00402000 r-xp 00000000 08:05 11976808
 /home/maris/soft/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/g.findfile
 00601000-00602000 r--p 00001000 08:05 11976808
 00602000-00603000 rw-p 00002000 08:05 11976808
 01821000-01842000 rw-p 00000000 00:00 0
 [heap]
   File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
 linux-gnu/etc/gui/wxpython/gui_core/forms.py", line 679, in
 OnRun
 ret = self.goutput.RunCmd(cmd, onDone = self.OnDone)
 linux-gnu/etc/gui/wxpython/gui_core/goutput.py", line 595,
 in RunCmd
 task = GUI(show = None).ParseCommand(command)
 linux-gnu/etc/gui/wxpython/gui_core/forms.py", line 2146, in
 ParseCommand
 mapset = grass.find_file(value, element)['mapset']
 KeyError
 'mapset'
 My GRASS version could be like r53972
Ticket URL: <http://trac.osgeo.org/grass/ticket/1808>
