[GRASS-dev] [GRASS GIS] #1796: wingrass7: some db.*-modules fails with dbf as db-backend (was: wingrass7: some db.*-modules fails)
GRASS GIS trac at osgeo.org
Fri Nov 23 07:13:45 PST 2012
 Reporter:  hellik    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  7.0.0
Component:  Database  |     Version:  svn-trunk
 Keywords:  dbf       |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hellik):
 Replying to [ticket:1796 hellik]:
 now tested with two mapsets
 mapset A with sqlite as db-backend
 mapset B with dbf as db-backend
 and a simple vector map with a simple table
 v.report.py map=gea option=area
 cat|gea|area
 1|1|217053697069.384
 all db.* are working in mapset A with sqlite as db-backend
 all db.* are '''not''' working in mapset B with dbf as db-backend
 g.copy vector from mapset B to mapset A is '''not''' working
 debug=3-output added as textfiles
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1796#comment:3>
