[GRASS-dev] [GRASS GIS] #1798: all relevant vector modules should have cats and where parameters
trac at osgeo.org
Fri Nov 23 11:54:03 PST 2012
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: where cats parameter | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:12 mlennert]:
> IIUC, you have some boilerplate code that can be inserted into vector
modules quite easily to add cats/where parameters. If that is the case,
and you can explain to me how to do it, then I can spend some time adding
this to modules. We can then still discuss whether virtual maps are a good
and feasible idea.
Here is a template:
/* define variables */
struct cat_list *cat_list = NULL;
/* parse options */
/* new: set category constraints */
if (field > 0)
cat_list = Vect_cats_set_constraint(&In, field, where_opt->answer,
cats_opt->answer);
for (line = 1; line <= nlines; line++) {
Vect_read_line(&In, Points, Cats, line);
/* new: check if categories are within constraints */
if (field > 0 && !Vect_cats_in_constraint(Cats, field, cat_list))
continue;
/* process line */
for (area = 1; area <= nareas; area++) {
Vect_get_area_cats(&In, area, Cats);
continue;
/* process area */
I hope the template is clear enough. This is already implemented in
v.buffer and v.hull.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1798#comment:13>
