[GRASS-dev] How to use a rules file in add-on script without hardcoding the path
Sat Nov 24 02:39:55 PST 2012
Robin Wilson wrote:
> 1. If I am running this script from somewhere outside of the GRASS
> scripts directory (eg. from somewhere in my home directory), how
> should I write my script so that it simply uses the reclass file in
> the same directory as the script? Currently my script contains the
> line:
> grass.run_command("r.reclass", input = options['input'], output = options['output'], rules = "./zerotonull.rules")
> where zerotonull.rules is the file that contains the declass rules,
> but this always gives an error saying it can't find that file.
You can't assume that the directory containing the script is the
current directory. However, sys.path[0] is usually the directory
containing the script.
> 2. If I want to distribute this script (either just to
> friends/colleagues or by adding it to the GRASS add-on repository),
> how should I set up my Makefile so that the reclass rules file gets
> put in the right place, and the script can then find it?
If the rules file is generated within the script, use Python's
tempfile module to select an appropriate location.
If the rules file is static data, it's probably simplest to embed the
data within the script as a raw string literal and feed it to
r.reclass via stdin, e.g. using grass.write_command().
