[GRASS-dev] why is r.li.setup unavailable in GRASS 7?
    Luca Delucchi
    lucadeluge at gmail.com
    Mon Nov 26 03:55:19 PST 2012
2012/10/30 Michael Barton <Michael.Barton at asu.edu>:
> OK. I'll try to test as soon as possible, though hopefully others with
> greater familiarity with the r.li modules can help in this. Without
> r.li.setup, all other r.li modules are useless.
I committed right now r.li.setup gui for wxpython. It's possible to
launch from GUI "raster -> Landscape path analisys -> Set up....." or
from command line using g.gui.rlisetup. Missing feature should be
added in the next months and testing is welcome.
I already know a bug if you launch  more times the wizard from the
second time you can move forward without the name of configuration
file and raster that are mandatory. If someone can help me for this
point....
> Michael
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
