[GRASS-dev] g.extension does not find wx.animation in svn
Anna Kratochvílová kratochanna at gmail.com
Wed Nov 28 07:25:25 PST 2012
On Wed, Nov 28, 2012 at 2:28 PM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Martin,
> thanks for your fast answer. The animation tool is now available in
> the menu after i made a subversion update. Everything works fine now.
Sorry Soeren, I should have told you. You can now access it also
through command line. Try
g.gui.animation --help
Anna
> Best regards
> Soeren
> 2012/11/28 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> 2012/11/28 Sören Gebbert <soerengebbert at googlemail.com>:
>>> The svn directory is missing indeed. So my question is: Where is
>>> wx.animation i really need it desperately.
>>> Any suggestions are welcome.
>> the tool has been move recently by Anna to trunk.
>> File -> Animation tool
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
