[GRASS-dev] d.mon x0 (substitution) in wingrass (i.spectral)?
Vaclav Petras wenzeslaus at gmail.com
Wed Nov 28 14:18:38 PST 2012
On 28 November 2012 21:26, Helmut Kudrnovsky <hellik at web.de> wrote:
> - any idea how to start for example d.mon start=PNG (or other driver working in windows)?
I'm not sure if the module actually works but you can bypass wxGUI
limitation by using
File -> Launch script
and run the file
gui/wxpython/gui_core/goutput.py
Maybe, you will have to add
#!/bin/env python
at the beginning of the file to make a script from it. I don't know if
this works on MS Windows. On Ubuntu, I'm just using
python filename.py
