[GRASS-dev] compiling animation, mapswipe, etc.
Helena Mitasova hmitaso at ncsu.edu
Thu Nov 29 21:03:44 PST 2012
Just a note that when compiling trunk on
MacOSX 10.6.8, running python2.6
I get Errors in:
/Users/helena/grassdev7/grass_trunk/general/g.version
/Users/helena/grassdev7/grass_trunk/gui/wxpython/animation
/Users/helena/grassdev7/grass_trunk/gui/wxpython/mapswipe
/Users/helena/grassdev7/grass_trunk/gui/wxpython/gmodeler
/Users/helena/grassdev7/grass_trunk/gui/wxpython/rlisetup
but mapswipe and gmodeler works anyway,
unfortunately animation does not although they all show the same error (see below).
Helena
  File "/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.animation", line 42, in <module>
    import wx
  File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
  File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
ImportError: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
make: *** [g.gui.animation.tmp.html] Error 1
  File "/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.mapswipe", line 40, in <module>
    import  wx
make: *** [g.gui.mapswipe.tmp.html] Error 1
Helena Mitasova
Associate Professor
Department of Marine, Earth, and Atmospheric Sciences
2800 Faucette Drive, Rm. 1125 Jordan Hall
North Carolina State University
Raleigh, NC 27695-8208
hmitaso at ncsu.edu
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
On Nov 29, 2012, at 3:09 PM, Anna Kratochvílová wrote:
> On Thu, Nov 29, 2012 at 3:12 AM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> On Nov 28, 2012, at 12:27 PM, Markus Neteler wrote:
>>> On Wed, Nov 28, 2012 at 6:35 PM, Carlos Grohmann
>>> <carlos.grohmann at gmail.com> wrote:
>>>> Hi
>>>> so, all modules under guy/wxpython that didn't compile show the same error:
>>>> /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so:
>>>> no matching architecture in universal wrapper
>>>> and both modules under visualization also have a common problem
>>>> "_wxEVT_ERASE_BACKGROUND", referenced from:
>>>>     __static_initialization_and_destruction_0(int, int)in gui.o
>>>> "_wxEVT_IDLE", referenced from:
>>>>     __static_initialization_and_destruction_0(int, int)in main.o
>>>> "_wxEVT_NULL", referenced from:
>>>> "_wxEmptyString", referenced from:
>>>>     wxStringBase::Init()      in gui.o
>>>> "_wxFrameNameStr", referenced from:
>>>>     MyFrame::MyFrame(wxString const&, int, int, gui_data*)in gui.o
>>>> "_wxPanelNameStr", referenced from:
>>>>     MyCanvas::MyCanvas(wxWindow*, int, wxSize const&)in gui.o
>>>> "_wxStaticTextNameStr", referenced from:
>>>> ld: symbol(s) not found for architecture x86_64
>>>> collect2: ld returned 1 exit status
>>>> lipo: can't open input file:
>>>> /var/folders/gf/8bwpz0412gs7706j57hdyb4h0000gn/T//ccTJ28Cm.out (No such file
>>>> or directory)
>>>> make: ***
>>>> [/Volumes/HDD/Users/guano/Documents/installs/GIS/grass/grass_trunk/dist.x86_64-apple-darwin12.2.0/bin/xganim]
>>>> Error 1
>> WxPython 2.8 can only be built 32bit (aka Carbon).  GRASS configuration will detect if wxPython is 64bit-ready, and force compilation in 32bits if not, but that only works if you configure GRASS at least 32bit.  ie 32bit only, or 32+64bit.  The default on Mt Lion is 64bit-only if you don't set any arch options.
>> This is why compilation with WxPython 2.9 works, because it can use 64bit Cocoa.  But then there is the runtime problem that has yet to be solved.
> What about the fix r40523 from the discussion mentioned by Markus?
> Could it be helpful in this case?
> Anna
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
>> - Marvin
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
