[GRASS-dev] [GRASS GIS] #1815: Problem with menu "path to GRASS database" in v.proj en r.proj windows
GRASS GIS trac at osgeo.org
Fri Nov 30 01:52:37 PST 2012
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Default     |     Version:  svn-trunk
 Keywords:              |    Platform:  Linux
      Cpu:  x86-64      |
 Browsing to the folder with the GRASS database in the menu "path to GRASS
 database" in v.proj and r.proj windows does not work. It always shows the
 home folder whatever folder you select.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1815>
