[GRASS-dev] compiling animation, mapswipe, etc.
Helena Mitasova hmitaso at ncsu.edu
Fri Nov 30 08:30:36 PST 2012
On Nov 30, 2012, at 10:08 AM, William Kyngesburye wrote:
> This could happen if you configured for wxPython 2.9 64bit, but didn't bundle it so it finds the old 32bit wxPython 2.8 in the system at runtime.  If you configure for wxPython 2.8 you should not get arch errors, at least if you make sure to configure 32+64bit.
I am pretty sure this is my case - can you please look at my configure and if possible give my some hints
on what should I do differently?
Thank you, Helena
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121130/8131d236/attachment.obj>
> On Nov 29, 2012, at 11:03 PM, Helena Mitasova wrote:
>> Just a note that when compiling trunk on
>> MacOSX 10.6.8, running python2.6
>> I get Errors in:
>> /Users/helena/grassdev7/grass_trunk/general/g.version
>> /Users/helena/grassdev7/grass_trunk/gui/wxpython/animation
>> /Users/helena/grassdev7/grass_trunk/gui/wxpython/mapswipe
>> /Users/helena/grassdev7/grass_trunk/gui/wxpython/gmodeler
>> /Users/helena/grassdev7/grass_trunk/gui/wxpython/rlisetup
>> but mapswipe and gmodeler works anyway,
>> unfortunately animation does not although they all show the same error (see below).
>> Helena
>> Traceback (most recent call last):
>> File "/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.animation", line 42, in <module>
>>   import wx
>> File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
>> File "/var/tmp/wxWidgets/wxWidgets-13~231/2.6/DSTROOT/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
>> ImportError: /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
>> make: *** [g.gui.animation.tmp.html] Error 1
>> File "/Users/helena/grassdev7/grass_trunk/dist.x86_64-apple-darwin10.8.0/scripts/g.gui.mapswipe", line 40, in <module>
>>   import  wx
>> make: *** [g.gui.mapswipe.tmp.html] Error 1
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
