[GRASS-dev] why is r.li.setup unavailable in GRASS 7?
Michael Barton Michael.Barton at asu.edu
Fri Nov 30 16:25:45 PST 2012
Luca,
r.li.setup does not yet compile in GRASS 7, at least on the Mac.
Here is the error:
anthgradpc7:g.version cmbarton$ cd /Users/Shared/grass_dev/grass7_dev/gui/wxpython/rlisetup
anthgradpc7:rlisetup cmbarton$ make
if [ "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup" != "" ] ; then GISRC=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/demolocation/.grassrc70 GISBASE=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0 PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:$PATH" PYTHONPATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:" LC_ALL=C /Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.rlisetup.tmp.html ; fi
  File "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup", line 32, in <module>
    import  wx
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
    import _core_
ImportError: /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
make: *** [g.gui.rlisetup.tmp.html] Error 1
rm g.gui.rlisetup.tmp.html
This may be the same error that is now affecting several GUI modules like map swipe, animation, and the graphical modeler.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Nov 26, 2012, at 8:42 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Thanks Luca
> C. Michael Barton
> USA
> On Nov 26, 2012, at 4:55 AM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> 2012/10/30 Michael Barton <Michael.Barton at asu.edu>:
>>> OK. I'll try to test as soon as possible, though hopefully others with
>>> greater familiarity with the r.li modules can help in this. Without
>>> r.li.setup, all other r.li modules are useless.
>> I committed right now r.li.setup gui for wxpython. It's possible to
>> launch from GUI "raster -> Landscape path analisys -> Set up....." or
>> from command line using g.gui.rlisetup. Missing feature should be
>> added in the next months and testing is welcome.
>> I already know a bug if you launch  more times the wizard from the
>> second time you can move forward without the name of configuration
>> file and raster that are mandatory. If someone can help me for this
>> point....
>>> Michael
>> ciao
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
