[GRASS-dev] datums not recognized by g.proj?
Markus Neteler
neteler at osgeo.org
Mon Oct 1 11:13:35 PDT 2012
(back to list)
On Mon, Oct 1, 2012 at 5:55 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> The worse problem is that locations are created ignoring the selected datum.
Thanks to the indication below I was able to understand what you mean.
So
1. Run GRASS in an existing location, set
g.gisenv set=DEBUG=3
leave GRASS.
2. Restart GRASS, enter Location Wizard, select "Select coordinate system"
3. Enter "utm"
4. Select "[x] Datum with associated ellipsoid"
Select Zone 29
Southern Hemisphere No
5. Datum code: eur50 [it is not ed50!]
Now find in the terminal:
D1/3: grass.script.core.start_command(): g.proj proj4=+proj=utm
+datum=eur50 datumtrans=-1
D1/3: grass.script.core.start_command(): g.proj -jf proj4=+proj=utm
+zone=29 +ellps=international +a=6378388.000 +rf=297.0 +datum=eur50
+dx=-87.0 +dy=-98 +dz=-121 +no_defs location=newLocation2
So, the datum= string is well there. I am using proj-4.7.0-5.fc17.x86_64.
> I assume that g.proj will simply use a default datum (WGS84??) during location creation.
No, see above.
But, yes, the resulting location does not contain the datum string:
GRASS 6.4.3svn (newLocation2):~ > g.proj -w
PROJCS["UTM Zone 29, Northern Hemisphere",
GEOGCS["international",
DATUM["unknown",
SPHEROID["International_1924",6378388,297]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
GRASS 6.4.3svn (newLocation2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universal Transverse Mercator
proj : utm
ellps : international
zone : 29
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : Meter
units : Meters
meters : 1
This is a problem. But I don't know if this ever worked (I never created a
location this way). Michael, please indicate the last GRASS version which
you found it working like this.
> However, running g.proj -d afterwards returns a "Datum parameters not present" error. So I
> can't tell what it is doing. This suggests to me that datum transform problem aside, many
> (most???) locations created by choosing projection and datum are wrong.
No, ONLY, if created in this style while being OK when using the EPSG code.
It is important to distinguish this.
> For example, if you have some data from a map that says it is in "Universal
> Transverse Mercator, Zone 29, European Datum 1950", searching on almost
> any of those terms in the projection and datum lists will give you a hit on the
> correct information. But doing the same search in the EPSG window gives you
> nothing, except for searching on "mercator" or "transverse"--and these give
> the wrong information. The best way to find the correct projection via the
> EPSG listing is if you already know that European Datum 1950 has a
> code name of "ED50".
(the code name is "eur50")
As Paul pointed out, PROJ4 doesn't seem to know much (anything?) about EUR50:
cs2cs -ld
__datum_id__ __ellipse___ __definition/comments______________________________
WGS84 WGS84 towgs84=0,0,0
GGRS87 GRS80 towgs84=-199.87,74.79,246.62
Greek_Geodetic_Reference_System_1987
NAD83 GRS80 towgs84=0,0,0
North_American_Datum_1983
NAD27 clrk66 nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat
North_American_Datum_1927
potsdam bessel towgs84=606.0,23.0,413.0
Potsdam Rauenberg 1950 DHDN
carthage clark80 towgs84=-263.0,6.0,431.0
Carthage 1934 Tunisia
hermannskogel bessel towgs84=653.0,-212.0,449.0
Hermannskogel
ire65 mod_airy
towgs84=482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15
Ireland 1965
nzgd49 intl towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
New Zealand Geodetic Datum 1949
OSGB36 airy
towgs84=446.448,-125.157,542.060,0.1502,0.2470,0.8421,-20.4894
Airy 1830
When creating locations using the EPSG way (my preferred method), it
uses GDAL/OGR instead of PROJ4 which knows about EUR50. Hence the
difference.
I do agree that getting the datum lost is bad. Perhaps we could enhance
g.proj to write it to PROJ_INFO when using the "Select coordinate system" way
of creating locations. Proof of concept:
GRASS 6.4.3svn (newLocation2):~ > eval `g.gisenv`
GRASS 6.4.3svn (newLocation2):~ > echo "datum: eur50" >>
$GISDBASE/$LOCATION_NAME/$MAPSET/PROJ_INFO
DATUM["European_Datum_1950",
UNIT["Meter",1]]
proj : utm
zone : 29
no_defs : defined
datum : eur50
unit : Meter
units : Meters
meters : 1
... solved :)
Markus
