[GRASS-dev] [GRASS GIS] #1753: Distance analysis
GRASS GIS trac at osgeo.org
Tue Oct 2 02:38:06 PDT 2012
  Reporter:  scorpionlegend92  |       Owner:  grass-dev@…
      Type:  task              |      Status:  closed
  Priority:  blocker           |   Milestone:  6.4.3
 Component:  Database          |     Version:  6.4.2
Resolution:  invalid           |    Keywords:  Distance
  Platform:  MSWindows 7       |         Cpu:  Unspecified
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [ticket:1753 scorpionlegend92]:
 > Hi,
 > I have to make distance analysis in Grass software. Can anyone provide
 me help in this regard how to use these command.; if possible, can anyone
 contact me and give me a demo on how to execute the task.
 > My main objective of using Grass GIS is to determine the minimum
 distance between one layer coordinates with other layer coordinates. I
 only have to display minimum/closest links in the form of line between two
 layers.
 > Also,when grass displays the line, where does it store the information
 of distance between the coordinates that are represented
 >  by the line.
 > Hope to have a quick response from your end.
 Please don't use the bug tracker for calls for help. Use the grass-users
 list for that. I'm closing this ticket.
 Your question lacks some details about types of data, but I would think
 that v.distance is your best bet.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1753#comment:2>
