[GRASS-dev] need update to core.create_location
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Oct 3 06:14:58 PDT 2012
Glynn Clements wrote:
> Consider whether the existing option should be renamed to datum_trans=.
> The abbreviation rules in 7.0 should accept datumtrans= as an
> abbreviation, but will also accept e.g. dt= or dtrans=.
Sounds like a good idea to me. Since we're breaking compatibility with
the scripts that used datum= instead of datumtrans= so that they will
need updated anyway, it seems like a good time to make this further
change to make things neater.
Paul
