[GRASS-dev] [GRASS GIS] #1744: v.out.ascii: export all columns
GRASS GIS trac at osgeo.org
Thu Oct 4 06:09:56 PDT 2012
 Reporter:  lucadelu              |       Owner:  martinl
     Type:  enhancement           |      Status:  assigned
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  v.out.ascii, columns  |    Platform:  All
      Cpu:  Unspecified           |
Comment(by martinl):
 Replying to [comment:5 hamish]:
 > did v.out.ascii columns= ever get fast?
 v.info n1 -t
 points=100000
 v.db.connect n1 -g
 1/n1|n1|cat|/home/martin/grassdata/nc_spm_08/user1/sqlite/sqlite.db|sqlite
 time v.out.ascii n1 out=n1-nocols --o
 real    0m0.305s
 user    0m0.288s
 sys     0m0.012s
 time v.out.ascii n1 out=n1-cols columns=* --o
 real    0m56.643s
 user    0m32.658s
 sys     0m28.166s
 Could be probably optimized.
 > It used to be unusably slow when there was > ~10000 db rows since it was
 opening and closing the db for every entry. I have a vague recollection
 that MarkusM commented at some point that
 DB is open once [source:grass/trunk/lib/vector/Vlib/ascii.c#L378]. For
 every feature is open select cursor
 [source:grass/trunk/lib/vector/Vlib/ascii.c#L639].
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1744#comment:7>
