[GRASS-dev] [GRASS GIS] #1744: v.out.ascii: export all columns
GRASS GIS trac at osgeo.org
Thu Oct 4 07:28:01 PDT 2012
 Reporter:  lucadelu              |       Owner:  martinl
     Type:  enhancement           |      Status:  assigned
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  v.out.ascii, columns  |    Platform:  All
      Cpu:  Unspecified           |
Comment(by mmetz):
 Replying to [comment:7 martinl]:
 > Replying to [comment:5 hamish]:
 > > did v.out.ascii columns= ever get fast?
 Testing welcome;) At least it got faster, question is if this is fast
 enough:
 In nc_spm_08, using sqlite mapset:
 g.copy vect=geonames_NC,my_geonames_N
 # GRASS 7
 time v.out.ascii input=my_geonames_NC layer=1 output=geonames_NC_7.ascii
 format=point
 columns=cat,GEONAMEID,NAME,ASCIINAME,ALTERNATEN,FEATURECLA,FEATURECOD,COUNTRYCOD,CC2,ADMIN1,POPULATION,ELEVATION,GTOPO30,TIMEZONE,MODIFICATI,PPLKEY,SRC_ID,MAINT_ID
 Fetching data...
 real    0m18.990s
 user    0m7.942s
 sys     0m21.478s
 # GRASS 6.4.svn
 time v.out.ascii input=my_geonames_NC layer=1 output=geonames_NC_64.ascii
 format=point
 real    5m24.340s
 user    2m9.232s
 sys     6m8.719s
 @Martin, r53278 and r53315:
 I know you don't want to test your own changes, but you could at least fix
 obvious compile warnings introduced by changes to be submitted...
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1744#comment:8>
