[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
GRASS GIS trac at osgeo.org
Thu Oct 4 23:44:10 PDT 2012
 Reporter:  scorpionlegend92                          |       Owner:  grass-dev@…
     Type:  defect                                    |      Status:  new
 Priority:  critical                                  |   Milestone:  6.4.3
Component:  Default                                   |     Version:  6.4.2
 Keywords:  v.distance, attribute of nearest feature  |    Platform:  MSWindows 7
      Cpu:  Unspecified                               |
 In v.distance, if I select "attribute of nearest feature given by
 to_column option" command and insert column name of nearest feature in
 "to" menu, v.distance command does not work.
 Column name that I use is "name" that is present in the attribute table. I
 uploaded the data in grass from .shp file for which it created a .dbf also
 at back-end in the GIS database software folder in my documents.
 Following error appears:
 v.distance -a --overwrite from=PERN86 at PERMANENT to=PERN86 at PERMANENT
 to_type=point,line output=same4 upload=cat,dist,to_attr column=to_cat,
 loc_dist,name to_column=name table=same4
 DBMI-DBF driver error:
 Column 'loc_dist' already exists (duplicate name)
 Cannot create table.
 Error in db_execute_immediate()
 ERROR: Unable to create table: 'create table same4 (from_cat integer,
 to_cat integer,  loc_dist double precision,  loc_dist double precision )'
 (Fri Oct 05 11:00:45 2012) Command finished (2 sec)
 If I select only "category of the nearest feature", and "minimum distance
 to nearest feature", then v.distance command work properly and create a
 .dbf file that contain the desired distance information. In such case,
 following output appears without any error.
 to_type=point output=same5 upload=cat,dist column=to_cat, loc_dist
 to_column=name table=same5
 1792 categories with more than 1 feature in vector map <PERN86 at PERMANENT>
 7225 distances calculated
 7225 records inserted
 Building topology for vector map <same5>...
 Registering primitives...
 7225 primitives registered
 14450 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 84
 Number of primitives: 7225
 Number of points: 0
 Number of lines: 7225
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 v.distance complete.
 (Fri Oct 05 11:01:18 2012) Command finished (2 sec)
 Please check and resolve why does this command create error and does not
 work when I select attribute in upload, string.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756>
