[GRASS-dev] [GRASS GIS] #1755: cannot create sqlite table for v.net.centrality
GRASS GIS trac at osgeo.org
Fri Oct 5 01:55:09 PDT 2012
 Reporter:  cmbarton          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Vector            |     Version:  unspecified
 Keywords:  v.net.centrality  |    Platform:  Unspecified
      Cpu:  Unspecified       |
Comment(by marisn):
 There is an old request to quote column names that would allow to use SQL
 reserved words as column names. See more: #578
 Second option would be to enhance parser to discard SQL reserved words as
 valid column parameters. AFAIK SQL-92 reserved word list isn't so long.
 Yes, I know, somebody will scream that PG, MySQL etc. have extra reserved
 words etc., still even blocking only the most common ones would make day
 for a user like Michal much better as he would be able to finish his task
 instantly instead of writing a bug report.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1755#comment:2>
