[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
trac at osgeo.org
Fri Oct 5 04:07:23 PDT 2012
Reporter: scorpionlegend92 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Resolution: duplicate | Keywords: v.distance, attribute of nearest feature
Platform: MSWindows 7 | Cpu: Unspecified
Changes (by mmetz):
* priority: critical => normal
Comment:
Replying to [comment:1 mlennert]:
> If I'm not mistaken, this is a duplicate of #672.
I think this is a different issue. Here, the table given with the table
option already exists, but the module wants to create a new table. This is
why the module fails.
In this case, overwriting the table (delete, then create anew) would be
dangerous because the original table can be attached to an existing
vector, resulting in loss of attributes for that vector.
Therefore I would rather check the table option for v.distance -a earlier
and print a more useful message, asking the user to use a table name that
does not yet exist. Decreasing priority.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756#comment:2>
