[GRASS-dev] [GRASS GIS] #1760: Cannot query vector network nodes
trac at osgeo.org
Sat Oct 6 18:44:17 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by cmbarton):
Here is additional information.
v.net does not create an attribute table for nodes, even if they are
created from a set of points that DO have an attribute table. For example
(using the sc_08 demo data):
v.net input=streets_wake at grass7vect_sqlite
points=firestations at grass7vect_sqlite output=firestation_network
operation=connect alayer=1 nlayer=2 thresh=100
creates a network of streets and firestations. The attributes from the
streets_wake file get copied over into the arcs of the new
forestation_network vector network file. But the attributes from the
firestations do not. This is the cause of the inability to query the
nodes. If I manually run v.db.connect to connect the nodes of
forestation_network to the forestations attribute table (connected to
nodes in layer 2), then I CAN query the nodes.
So the main problem is in how v.net creates networks not how v.what (and
wxgui) queries the network. In fact, there is no problem querying nodes in
layer 2 once they have an attribute table.
BUT, querying nodes still should at least show the cat values, even if
there is no attribute table. So there is still a query issue here.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1760#comment:1>
