[GRASS-dev] spanning tree and steiner tree problems?
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 8 08:53:39 PDT 2012
On 07/10/12 08:27, Michael Barton wrote:
> Hi Moritz,
> Thanks to your help, I now have been able to run through a number of the
> vector network operations. Two that don't seem to work are v.net.steiner
> and v.net.spanningtree. But perhaps I am not doing it right.
> Here is the setup using Highschools from the schools_wake vector and
> streets_wake in the sc_08 demo data set.
> First I connect highschools (previously extracted from schools_wake)
> with the streets.
> v.net <http://v.net> --overwrite input=streets_wake at grass7vect_sqlite
> points=highschools at spatialtech2012 output=hs_net operation=connect
> alayer=1 nlayer=2 thresh=200
Are you sure there are highschools connected to the network (is this the
schools_wake layer) ?
> When I run v.net.stiener, it gives no error but doesn't create anything
> either. Here is the command:
> v.net.steiner input=hs_net at spatialtech2012 output=hs_steiner type=line
> alayer=1 nlayer=2
> tcats=4,7,11,12,37,49,50,65,67,69,77,83,91,101,103,115,117,138,153,158,164,165
When I try to do this on the entire streets_wake network, my machine
immediately goes into disk swap and I don't have the time to wait and
see if and when it finishes. However, when I cut out a small part of the
network, it works as expected.
> When I run v.net.spanningtree, I do get results, but it is a complex
> street network that is almost the same as the original street network.
> Here is the command I am using:
> v.net.spanningtree --overwrite input=hs_net at spatialtech2012
> output=hs_spanningtree alayer=1 nlayer=2
See the attached image for results I get with the streets_wake layer. In
black the original layer and in green the spanning tree. As you can see
it seems to have worked.
It seems that this module ignores any nodes you might have on layer 2
and just happily finds the minimum spanning tree of the entire network,
using the intersections as nodes. I'm no expert on spanning trees and
cannot say whether this is expected behavior or a bug.
Moritz
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121008/c740033d/attachment-0001.png>
