[GRASS-dev] Vect_read_line -> ERROR: G_calloc
"ifj. Stefán István"
istefan at stef.hu
Mon Oct 8 09:22:26 PDT 2012
Hello!
I'm trying to open a vector map with the Grass 6 API, but when I try to
read from the map, I get the following error message:
ERROR: G_calloc: unable to allocate 1861156242 * 4 bytes at
allocation.c:144
The map I tr to read from is quite small, has only 3 features (one
polyline and two boundaries).
I try to use this code to read from the map:
extern "C" {
#include "grass/gis.h"
#include "grass/Vect.h"
#include <iostream>
int main(int argc, char **argv){
using namespace std;
struct Map_info Map;
int ret;
G_gisinit(argv[0]);
ret=Vect_open_old(&Map, "polygonmap", "PERMANENT");
cout<<"open level: "<<ret<<endl;
cout<<"maptype: "<<Vect_maptype_info(&Map)<<endl;
struct line_pnts line_p;
struct line_cats line_c;
Vect_read_line(&Map, &line_p, &line_c,1);
return ret;
What am'I doing wrong?
Thanks for your help in advance,
István
