[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
GRASS GIS trac at osgeo.org
Tue Oct 9 01:04:43 PDT 2012
  Reporter:  scorpionlegend92  |       Owner:  grass-dev@…
      Type:  defect            |      Status:  reopened
  Priority:  normal            |   Milestone:  6.4.3
 Component:  Default           |     Version:  6.4.2
Resolution:                    |    Keywords:  v.distance, attribute of nearest feature
  Platform:  MSWindows 7       |         Cpu:  Unspecified
Changes (by scorpionlegend92):
  * status:  closed => reopened
  * resolution:  duplicate =>
Comment:
 This problem is still appearing in 6.4.3svn version. Following error
 appears:
 v.distance -a --overwrite from=PERN at PERMANENT to=AKDNCombine at PERMANENT
 to_type=point,line output=distancecheck9 upload=cat,dist,to_attr
 column=cat,ping11,name to_column=name table=dist9
 DBMI-DBF driver error:
 Column 'ping11' already exists (duplicate name)
 Cannot create table.
 Error in db_execute_immediate()
 ERROR: Unable to create table: 'create table dist9 (from_cat integer, cat
 integer, ping11 double precision, ping11 double precision )'
 (Tue Oct 09 12:58:25 2012) Command finished (12 sec)
 Please check and confirm. If I un-check the attribute option from the
 menu, this command is working properly, but not by selecting the command.
 It fails to accept   column name that will store distance information.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756#comment:7>
