[GRASS-dev] pygrass is into GRASS trunk
Vaclav Petras
wenzeslaus at gmail.com
Wed Oct 10 07:53:52 PDT 2012
Hi Pietro and devs,
I was using the standalone GSOC version of pygrass for some time and
now I switched to the one in trunk. I'm using mainly vector classes
but I can say that the three points promised in introduction were
really achieved. pygrass is fast, easy to use and if needed you can
always use it together with ctypes.
Well done, Pietro!
Vaclav
On 10 October 2012 15:22, Pietro <peter.zamb at gmail.com> wrote:
> Dear GRASS Developers,
> I am pleased to announce that the pygrass library, developed during
> the Google Summer of Code 2012, is now on GRASS trunk and need to be tested.
> Before to continue the announcement, if you prefer the html version of this
> message please see: https://gist.github.com/gists/3864411
> The pygrass library has been developed take into account three main aspects,
> in the order:
> 1. *simplicity*, GIS it's an already complex subject, and we want to make
> the API as simple/natural/intuitive as possible but at the same time
> trying to respect the GRASS work-flow and nomenclature to make it easier
> to find information on the GRASS developer manual;
> 2. *flexibility* even if pygrass want to provide an high level map
> interaction, internally used some classes that work with the
> GRASS API at very low level, such as Segment, Bbox, Ilist classes.
> Every time that a C struct has been used by a class, to leave the user
> free to implement their own logic, the ctypes pointer of the C strct
> it's available under the attribute name that start with "c_*";
> 3. *performance* pygrass makes heavy use of the C GRASS functions
> every time that this is possible.
> The pygrass library is divided in three main parts: Raster, Vector, and Modules.
> Below some small samples, of an interactive python shell, are reported to better
> understand how users and developers could interact with the *pygrass* library.
> All the following examples use the maps present in the North Carolina mapset.
> Raster
> All the raster classes read and write meta-data like: categories and history.
> The *pygrass* interface for raster maps is divided in 4 classes that represent
> different ways to interact with rasters. In order to give greater freedom of
> implementation to users and developers, each class uses a different C API,
> providing the tools to fit different needs.
> The **RasterRow** class reads the content of the raster row by row and writes it
> in a sequential mode: row after row. Read and write the same map at the same
> time is not supported by the RasterRow class.
> The **RasterRowIO** class implements a row cache that allows users to read and
> re-read raster rows randomly.
> The **RasterSegment** class divides the map into several tiles, each tile is
> saved into a file.With this class it is possible to read and write the pixel
> value randomly at the same time in the same map.
> The **RasterNumpy** class inherits from a *numpy.memmap* class and allows
> users to interact with the map as numpy matrix.
> All the Raster classes shared common methods to open, read and get
> raster information.
> Do simple operation with the *RasterRow* class: ::
> >>> from grass.pygrass.raster import RasterRow
> >>> elev = RasterRow('elevation')
> >>> elev.exist()
> True
> >>> elev.name # get the raster name
> 'elevation'
> >>> elev.mapset
> 'PERMANENT'
> Now open the raster in a read mode, get raster information and read the rows: ::
> >>> elev.open('r') # open in read mode
> >>> elev.is_open()
> True
> >>> elev.range
> (55.578792572021484, 156.32986450195312)
> >>> for row in elev[:5]: # show the first 5 rows
> ... print(row[:3]) # show the first 3 columns of each row
> [ 141.99613953 141.27848816 141.37904358]
> [ 142.90461731 142.39450073 142.68611145]
> [ 143.81854248 143.54707336 143.83972168]
> [ 144.56524658 144.58493042 144.86477661]
> [ 144.99488831 145.22894287 145.57142639]
> ... print(row[:3] < 144)
> [1 1 1]
> [1 1 1]
> [1 1 1]
> [0 0 0]
> [0 0 0]
> Open a new raster map, save, rename and remove: ::
> >>> new = RasterRow('new')
> >>> new.exist()
> False
> >>> new.open('w', 'CELL') # open a new CELL map in write mode
> >>> for row in elev:
> ... new.put_row(row < 144) # write the boolean row
> >>> new.close()
> >>> new.mapset
> 'user1'
> >>> new.name
> 'new'
> >>> new.name = 'new_name' # rename the map changing the attribute value
> >>> new.name
> 'new_name'
> >>> new.exist()
> True
> >>> new.remove() # remove the map
> >>> new.exist()
> False
> >>> elev.close()
> Almost the same operations are available for the other Raster classes,
> please see the documentation:
> http://www.ing.unitn.it/~zambelli/projects/pygrass/raster.html
> Vector
> The *pygrass* interface defines two classes to work with vector maps, the first
> class **Vector** loads a vector map without the GRASS topology, while the
> **VectorTopo** class supports the topology. The *pygrass* library implements the
> geometry features: **Point**, **Line**, **Boundary**, **Area**, **Isle**, each
> class has its method to return vector information or to compute its properties
> such as the length of a line, the distance between two points, or between a
> point and a line, etc.
> Here just small samples to better understand how it is now possible to interact
> with the GRASS vectors and features are reported: ::
> >>> from grass.pygrass.vector import VectorTopo
> >>> municip = VectorTopo('boundary_municp_sqlite')
> >>> municip.open()
> >>> municip.number_of("areas")
> 3579
> >>> municip.number_of("islands")
> 2629
> >>> municip.number_of('pizzas') # suggest the right vector type if wrong
> Traceback (most recent call last):
> ValueError: vtype not supported, use one of: 'areas', 'dblinks', 'faces',
> 'holes', 'islands', 'kernels', 'line_points', 'lines', 'nodes',
> 'updated_lines',
> 'updated_nodes', 'volumes'
> Suppose that we want to select all and only the areas that have a surface bigger
> than 10000 m2: ::
> >>> big = [area for area in municip.viter('areas')
> ... if area.alive() and area.area() >= 10000]
> Then it is possible to sort the areas, with: ::
> >>> from operator import methodcaller as method
> >>> big.sort(key = method('area'), reverse = True) # sort the list
> >>> for area in big[:3]:
> ... print area, area.area()
> Area(3102) 697521857.848
> Area(2682) 320224369.66
> Area(2552) 298356117.948
> The *pygrass* library implements classes to access the Table attributes, to
> manages the database connection, to make queries, to add and remove columns.
> Read and write the **Link** connection with the database of a vector map: ::
> >>> municip.dblinks
> DBlinks([[Link(1, boundary_municp, sqlite)]])
> >>> link = municip.dblinks[1]
> >>> link.number
> 1
> >>> link.name
> 'boundary_municp'
> >>> link.table_name
> >>> link.driver
> 'sqlite'
> >>> link.database[-30:]
> 'north_carolina/user1/sqlite.db'
> >>> link.key
> 'cat'
> >>> link.name = 'boundary'
> >>> link.driver = 'pg'
> >>> link.database = 'host=localhost,dbname=grassdb'
> >>> link.key = 'gid'
> From the Link object it is possible to instantiate a **Table** object where the
> user could make simple query with the **Filters** object: ::
> >>> table = link.table()
> >>> table.filters.select('cat', 'COUNTY',
> 'AREA','PERIMETER').order_by('AREA').limit(3)
> Filters('SELECT cat, COUNTY, AREA, PERIMETER FROM
> boundary_municp_sqlite ORDER BY AREA LIMIT 3;')
> >>> cur = table.execute()
> >>> for row in cur.fetchall():
> ... print repr(row)
> ... # cat, COUNTY, AREA, PERIMETER
> (1, u'SURRY', 0.0, 1415.331)
> (2, u'SURRY', 0.0, 48286.011)
> (3, u'CASWELL', 0.0, 5750.087)
> In this way it is possible to work with table properties like name/rename the
> table and add/remove/rename/cast the columns of the table: ::
> >>> table.name
> >>> table.columns
> Columns([(u'cat', u'integer'), ..., (u'ACRES', u'double precision')])
> >>> table.columns.names()
> [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ..., u'ACRES']
> >>> table.columns.types()
> [u'integer', u'integer', u'double precision', ..., u'double precision']
> >>> table.columns.add('n_pizza', 'int4')
> >>> table.columns.names()[-1]
> u'n_pizzas'
> >>> table.columns.rename(u'n_pizzas', u'n_pizzas_per_person')
> >>> table.columns.cast(u'n_pizzas_per_person', 'float8')
> >>> table.columns.items()[-1]
> (u'n_pizzas_per_person', u'float8')
> >>> table.columns.drop(u'n_pizzas_per_person')
> For more examples with the Vector class, please see the documentation:
> http://www.ing.unitn.it/~zambelli/projects/pygrass/vector.html
> Modules
> The *pygrass* **Module** class is compatible with the *grass.run_command*
> syntax. ::
> >>> from grass.pygrass.modules import Module
> >>> slope_aspect = Module("r.slope.aspect", elevation='elevation',
> ... slope='slp', aspect='asp',
> ... format='percent', overwrite=True)
> But it is possible to create a run able module object, change some attributes
> and run later: ::
> >>> slope_aspect = Module("r.slope.aspect", elevation='elev',
> ... format='percent', overwrite=True, run_=False)
> >>> slope_aspect.inputs['elevation']
> Parameter <elev> (required:yes, type:raster, multiple:no)
> >>> slope_aspect.inputs["elevation"].value = "elevation"
> >>> slope_aspect.inputs["format"]
> Parameter <format> (required:no, type:string, multiple:no)
> >>> print slope_aspect.inputs["format"].__doc__ # get help for
> the input parameter
> format: 'degrees', optional, string
> Format for reporting the slope
> Values: 'degrees', 'percent'
> >>> slope_aspect.inputs["format"].value = 'percents' # manage and
> check the errors
> ValueError: The Parameter <format>, must be one of: ['degrees', 'percent']
> >>> slope_aspect.inputs["format"].value = 'percent'
> >>> slope_aspect.run()
> Or it is possible to initialize a module, and give the parameters later, like a
> python function: ::
> >>> slope_aspect = Module("r.slope.aspect")
> >>> slope_aspect(elevation='elevation', slope='slp', aspect='asp',
> Moreover the *pygrass* Module allows the user to run GRASS modules in a
> different process and to manage (wait/kill/terminate) the process, and to
> manage/record the output of the standard error and the standard output, in a way
> that is easier than using the actual Python API of GRASS. ::
> >>> slope_aspect = Module('r.slope.aspect')
> ... overwrite=True, finish_=False)
> >>> slope_aspect.popen.wait() # *.kill(), *.terminate()
> 0
> >>> out, err = slope_aspect.popen.communicate()
> >>> print err
> 100%
> Aspect raster map <asp> complete
> Slope raster map <slp> complete
> For more examples with the Module class, please see the documentation:
> http://www.ing.unitn.it/~zambelli/projects/pygrass/modules.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
