[GRASS-dev] improving v.in.wms [you mean r.in.wms?]
stepan.turek
stepan.turek at seznam.cz
Wed Oct 10 12:53:05 PDT 2012
I have added r.in.wms2 module with experimental WMTS support into GRASS
AddOns.
I have tested it on IGN Geoportal and Czech Cadastral Geoportal. The
examples can be found on manual page.
Currently, I work on Tiled-WMS support in r.in.wms2.
Stepan
---------- Původní zpráva ----------
Od: Hamish <hamish_b at yahoo.com>
Datum: 1. 10. 2012
Předmět: Re: [GRASS-dev] improving v.in.wms(http://v.in.wms) [you mean r.in.
wms(http://r.in.wms)?]
"Štěpán wrote:
> WMTS support and username/passoword would be useful. I will
> look at WMTS standard and try to implement it.
Hi
see existing gpl2 code (by me anyway..) for it here:
http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/scripts/gpstile_
fetch_and_assemble.sh?revision=2680&content-type=text%2Fplain
(http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/scripts/gpstile_fetch_and_assemble.sh?revision=2680&content-type=text%2Fplain)
maybe it is easy to port with just minor modifications?
see also Tiled-WMS (like NASA OnEarth server now is restricted to)
http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/scripts/gpstiled_
wms_fetch_and_assemble.sh?revision=2677&content-type=text%2Fplain
(http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/scripts/gpstiled_wms_fetch_and_assemble.sh?revision=2677&content-type=text%2Fplain)
The tiled-WMS method is already implemented for GRASS in the r.in.onearth
(http://r.in.onearth)
addon script. maybe much much easier using 'g.region -a' magic.
Hamish"
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121010/386cbd9b/attachment.html>
