[GRASS-dev] Grass Libraries
Rainer M Krug r.m.krug at gmail.com
Thu Oct 11 03:59:33 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 11/10/12 11:39, Markus Neteler wrote:
> On Thu, Oct 11, 2012 at 10:24 AM, Fernando Sierra <fernando.sierra at ciemat.es> wrote:
>> Hi,
>> What libraries I need to install in each cluster-node to run grass in a cluster? With SGE or
>> Slurm?
> What we do on our cluster: - install GRASS in /usr/local/ - export /usr/local/ via NFS to the
> blades - use Grid Engine (SGE), see GRASS Wiki
> Like this we have a single installation to maintain which is visible to all cluster nodes.
effectively the same here, only that, as I am only a "normal" cluster user, I installed it GRASS
in my home directory.
Rainer
> Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://www.enigmail.net/
iEYEARECAAYFAlB2ppUACgkQoYgNqgF2egqMfwCfa4QlfVr+Qkt6kwqf+TSMGxIJ
v3kAmQGQpnYzzKbS4HjD88kz2+yqMtX5
=7Uqu
-----END PGP SIGNATURE-----
