[GRASS-dev] [GRASS GIS] #1763: Cannot scan date: on mapinfo imported map
GRASS GIS trac at osgeo.org
Mon Oct 15 05:46:28 PDT 2012
 Reporter:  pertusus  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.3
Component:  Vector    |     Version:  6.4.2
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 I import a mapinfo .mif (with .mid) mapset, with the following command:
 v.in.ogr dsn=cartorisque_departement_01/
 layer=01_ATLAS_INONDATION_ZONE_INONDABLE output=zone_inondable_01
 But when I do a v.db.select on the result, I get
 v.db.select zone_inondable_01
 cat|IDENT|DOCUMENT|AUTEUR|DATE_APPROBATION|DATE_APPROBATION_AFFICHEE|PRECISION|RISQUE|THEME|CODE_DEGRE|DEGRE|LABEL|LIEN_RAPPORT|TAILLE_RAPPORT|LIEN_REGLEMENT|TAILLE_REGLEMENT|FOURNISSEUR|DATE_IMPORT
 DBMI-SQLite driver error:
 Cannot scan date:
 ERROR: Unable to fetch data from table <zone_inondable_01>
 Reading the code, I see in db/drivers/sqlite/fetch.c, l. 167
             ns = sscanf(text, "%4d-%2d-%2d", &dt->year, &dt->month,
 &dt->day);
             if (ns != 3) {
                 append_error("Cannot scan date:");
                 append_error(text);
                 report_error();
                 return DB_FAILED;
 The columns with DATE type are DATE_APPROBATION and DATE_IMPORT:
  v.info -c zone_inondable_01
 Displaying column types/names for database connection of layer 1:
 INTEGER|cat
 INTEGER|IDENT
 CHARACTER|DOCUMENT
 CHARACTER|AUTEUR
 DATE|DATE_APPROBATION
 CHARACTER|DATE_APPROBATION_AFFICHEE
 CHARACTER|PRECISION
 CHARACTER|RISQUE
 CHARACTER|THEME
 CHARACTER|CODE_DEGRE
 CHARACTER|DEGRE
 CHARACTER|LABEL
 CHARACTER|LIEN_RAPPORT
 CHARACTER|TAILLE_RAPPORT
 CHARACTER|LIEN_REGLEMENT
 CHARACTER|TAILLE_REGLEMENT
 CHARACTER|FOURNISSEUR
 DATE|DATE_IMPORT
 $ ogrinfo . 01_ATLAS_INONDATION_ZONE_INONDABLE DATE_IMPORT
 shows that all dates as null, like
   DATE_APPROBATION (Date) = (null)
   DATE_IMPORT (Date) = (null)
 but I am not sure it is true. To check all are null I used:
 ogrinfo . 01_ATLAS_INONDATION_ZONE_INONDABLE |grep 'DATE_APPROBATION
 \|DATE_IMPORT '
 I have put a tar.gz to reproduce the issue at
 http://pertusus.free.fr/bug_grass.tar.gz
 The script is cartorisque_departement.sh you could have to edit it to find
 grass.
 wget http://pertusus.free.fr/bug_grass.tar.gz
 tar xzvf bug_grass.tar.gz
 cd bug_grass && ./cartorisque_departement.sh
 Maybe the bug is somewhere in ogr, I cannot really tell.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1763>
